Hey Everyone,
Everyone body knows that high definition videos/movies is the best, right? RIGHT!
I have a few animes that are in (.mkv) format with soft-subs. I'm trying to mux them all into (.avi) and be playable with the PS3.
But for some reason I couldn't play the file.
>>In this thread<<
- Reasons/Outside Info
- Steps
- Ending Results
Why do you want to convert them to (.avi)'s?
PS3's can't play (.mkv) files, but it can play (.avi) files.
But the PS3 doesn't support soft-subs!
PS3's can play DIVX/XVID soft-subs using a program called AVIAddXSubs. Yep, it's true
That is why I'm trying to convert/mux (.mkv) to (.avi) without losing any video quality, and so that I can have subtitles WITHOUT! Re-encoding
.::MY FAIL METHOD::.
So this is where I started my journey, to find a way to play animes with soft-subs without re-encoding/losing quality on the PS3
1) Extracted (.mkv) files using MKVExtractGUI2.
2) Converted the H.264 (VIDEO) to (.avi) using avc2avi.
3) Converted the AAC (AUDIO) to AC3 using Xilisoft Video Converter Ultimate 6.
4) Muxed the VIDEO and AUDIO together using VirtualDUB MOD.
5) Used AVIAddXSubs to add in the subs.
6) Ending result was a (.divx) file...good good
Watched it on the computer (Didn't see subtitles, that's normal) the video and audio...all in tact.
Placed the video file in a usb and turned it on the PS3...
>>ERROR!<<
The PS3 said...
"The Data type is not supported. (800288C0)"
Here is a MediaInfo...info?
This file I converted the AUDIO to 5.1 AC3.
This is not an anime show. It's a Movie sample that I download off the internet.Code:Format : DivX Format/Info : Hack of AVI File size : 106 MiB Duration : 24mn 42s Overall bit rate : 602 Kbps Video ID : 0 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Format settings, GOP : M=6, N=12 Codec ID : h264 Duration : 24mn 41s Bit rate : 268 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 3:2 Frame rate : 23.976 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.032 Stream size : 47.3 MiB (45%) Title : Video Writing library : x264 core 56 svn-676 Encoding settings : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=5 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=268 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 Audio ID : 1 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 2000 Duration : 24mn 42s Bit rate mode : Constant Bit rate : 320 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 44.1 KHz Stream size : 56.5 MiB (53%) Alignment : Split accross interleaves Interleave, duration : 42 ms (1.00 video frame) Interleave, preload duration : 500 ms Title : Audio Text Format : DivX Subtitle Codec ID : DXSB Codec ID/Info : Subtitle in AVI from DivX networks Width : 720 pixels Height : 480 pixels Bit depth : 4 bits Stream size : 810 KiB (1%) Title : Subtitle - en-xx;02
It was in (.mkv - 720p). Still did not work on the PS3.
Anyone have any ideas why this method didn't work?Code:Format : DivX Format/Info : Hack of AVI File size : 21.2 MiB Duration : 1mn 8s Overall bit rate : 2 583 Kbps Video ID : 0 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : h264 Duration : 1mn 8s Bit rate : 2 185 Kbps Width : 1 280 pixels Height : 544 pixels Display aspect ratio : 2.35:1 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.131 Stream size : 17.9 MiB (85%) Title : Video Audio ID : 1 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 2000 Duration : 1mn 8s Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Stream size : 3.15 MiB (15%) Alignment : Split accross interleaves Interleave, duration : 42 ms (1.01 video frame) Interleave, preload duration : 500 ms Title : Audio Text Format : DivX Subtitle Codec ID : DXSB Codec ID/Info : Subtitle in AVI from DivX networks Width : 1 280 pixels Height : 544 pixels Bit depth : 4 bits Stream size : 37.7 KiB (0%) Title : Subtitle - en-xx;02
And any ideas to make this work o.o?
Please keep this thread up. I haven't seen many threads that is about soft-subs movies and on [ANIME/TV SERIES] MKV --> AVI (PS3).![]()
I don't believe the PS3 supports AVC inside an AVI container (Or a .divx container, which is just a hacked AVI anyway).
I generally stream non-natively playable material to the PS3, so subs aren't an issue. For AVC 720p material I usually use MultiAVCHD to create a compliant AVCHD format, which the PS3 is happy with, and which supports soft subs etc.Read my blog here.
Thank you for the reply
Hmm...so the PS3 doesn't support AVC inside an AVI container...
So the only way for the PS3 to support the AVI container is to encode the AVC to something else?
That would mean a loss of quality...
So I guess the method I'm using now is to be put aside.
I'm also guessing that you're streaming by using PS3 Media Server or TVersity?
I was wondering if we can copy the "Transcode" videos to the PS3 HDD.
But I hear it can go up to 90gb's +
Thank you for the tip with the AVC 720p video.
But can this also be done with a 1080p?
I'm guessing yes.
Yes. AVCHD supports all valid resolutions, from 480i upwards.
Note, however, that most mkv files are not valid resolutions (including your example), because they have been cropped during encoding. Valid resolutions are 1280 x 720, and 1920 x 1080 (or 1440 x 1080). 1280 x nnn, where nnn does not equal 720, means a re-encode is required.
Eventually you may find it is easier to get a separate, more capable media player, such as a WDTV or similar (I have one, as well as the PS3)Read my blog here.
Thank you for the information. Never knew about the AVCHD program
Guns1inger, is there any other way to play a video file without losing it's video quality with subs?
There should be a alternative way then re-encoding the whole video again.
::EDIT::
Looks like there was no audio after I converted/mux/idk with AVCHD.
::EDIT::
I found the reason why...
::EDIT::
Maybe not...Last edited by mooshimuushi; 21st Aug 2010 at 02:21. Reason: Adding some information.
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 02:20 -
Backup DVD to mkv with soft subs
By rapaz in forum DVD RippingReplies: 28Last Post: 23rd Dec 2009, 23:16 -
How to convert MKV with soft subs to AVI using DVDFab 6.x
By Shilar in forum User guidesReplies: 0Last Post: 28th Aug 2009, 09:15 -
How do I put soft subs into my iPod h.264 MP4 files?
By FallenAngelII in forum SubtitleReplies: 1Last Post: 4th Nov 2008, 15:31 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 09:25
